Lowering the memory limit on Aurora compute nodes on June 23, 2025
ALCF is going to reduce user-accessible memory on Aurora compute nodes, by the equivalent of a node's HBM capacity (128GB), on June 23, 2025, to approximately 960GB between DDR5 + HBM, regardless of how applications utilize each memory tier.
Note that, currently on Aurora, ALCF enforces a memory limit on compute nodes such that users are allowed between MemTotal - 64GB (soft limit) and MemTotal - 32GB (hard limit), effectively reserving between 32GB and 64GB for system use. MemTotal refers to approximately 1TB of DDR5 plus 128GB of HBM.
However, with our current approach due to limitations in cgroup-based enforcement, we are unable to constrain memory usage at the per-NUMA-node level. In other words we can't limit the memory used on DDR5 separately from HBM NUMA nodes. The kernel only gives the capability to limit via overall bytes allocated.
This results in often out-of-memory (OOM) conditions in DDR5 NUMA nodes 0 and 1, Reducing our ability to protect system services and prevent node-wide panics triggered by OOMs.
